Did u see my post above. Built in ram is the issue. I called DJI and said that and that’s why its not on the supported list from dji. The samsung Tab S6 lite will be added they said
Good response! I had wondered about memory. I bought my Tab A 8 used so I’m stuck with what I have unless I lay out another wad of cash. If it becomes more of a problem, I may try memory optimizer software before I swallow hard.
I just did all the steps outlined with my Tab A 8, disabled apps, removed them, put it in airplane mode, turned off HD and caching, etc. It seems totally usable but I found the screen unfortunately isn’t super bright and it’s shiny so I had trouble seeing in bright sunlight.
Can’t be only the ram. I use the iPad5 which has the same ram as the Tab a8 (2GB) and it works flawlessly.
I used the QR reader to scan the code on the Mavic Air 2 online user guide and DJI Fly loaded and ran without problems.
Hej. Mam t290 i mini2, działa, ale software trzeba zainstalować ze strony DJI, nie sklepu play. Pozdrawiam
How do you side load the DJI Fly app to a Tab A?
It works perfect with the Samsung SM-T290 tablet, now with dji fly version 1.5
Can anyone make it work with a SM-T350?
Tengo a Galaxy Tab A (8.0" 2019) SM-T290 con Android 11, utilizando la DJI Fly 1.4.12(1430), el día de hoy me percate que en algunas ocasiones la imagen se congela, nada complicado para mi.
Saludos de La Serena Chile
I use the Samsung Tab A SM-T307U and have no problems with it.
Looking to use this TABLET 2020 version (SM-T307U ) with DJI FLY (Mavic air 2)–any concerns?
Hi…will have this unit this week…How happy are you? does it lag on the Fly App? I have Lenovo M and have lost connections at times.
I haven’t encountered any issues with the Samsung Tab A SM-T307U, it has been quite dependable so far.
anyone here knows if it works for Galaxy Tab А8 10.5 LTE SM-X205?
@Robert_Murphy if you must use that mobile device, you could try installing older versions of DJI Fly to potentially find a version that will still work as expected.
