HOW TO: Transfer DJI TXT flight logs from Android devices
Flight Reader 1.6.3 (or higher) is able to to transfer TXT flight logs directly from Android devices (phones/tablets/DJI RCs) that are connected to your computer with a USB cable. These transfers are quick and don’t require uploading your flight logs to the Internet.
For Android phones/tablets, follow these steps to sync new TXT flight logs:
  • Connect the Android phone/tablet to your computer with a USB cable that supports data transfers like this one (some USB cables are for charging only).
  • After connecting the USB cable, you should see a prompt on the Android device to select a USB mode. Choose “File Transfer”.
  • If Flight Reader is not running, start Flight Reader and any new flight logs will be automatically synced and processed as soon as Flight Reader starts.
  • If Flight Reader is already running, choose “File” → “Sync Flight Logs” from the top menu in the main Flight Reader window to manually sync all new flight logs.
For DJI RCs (with a screen), follow these steps to sync new TXT flight logs:
  • Connect the DJI RC to your computer with a USB cable that supports data transfers like this one (some USB cables are for charging only).
