Flight Reader 1.6.9 released
A new version of Flight Reader is available. Release 1.6.9 includes the following changes:
  • Added support for processing Neo flight logs.
  • When using the “File” → “Sync Flight Logs” feature to sync flight logs from a local Android device (as documented here), flight logs will also be synced from Litchi if installed.
  • Removed the repeated “Auto returning to home” placemarks from the map and KML while the aircraft is returning home.
  • When adding new fields in the “Logs/Reports” section of the Flight Reader Options window, the new field is added below (instead of above) the field selected in the “Selected Fields” list.
  • The “Sync History” menu item is only displayed in the “File” menu when history data is available.
  • Resolved issue causing Flight Reader to crash when attempting to open an aircraft log while the associated CSV file was open in Excel or other CSV reader that locks the CSV file upon opening it.
