Download Flight Record from iPhone to Windows 11?
I had a complicated explanation of how to do this for a Mavic Air 2, involving iTunes, but I’ve lost track of it. Can somebody please direct me to Mike’s write-up?
Or maybe there’s a simpler way now?
Cheers! – jclarkw
Mike – Fantastic! I’m eager to try your “new” Flight Log Transfer Service, as it sounds a huge improvement over the old iTunes approach.
While digging in Google search, I found that Apple has a new approach also, “Apple Devices,” although this method requires installing a file-sharing app on the iPhone as well as the one on the PC.
Very Best Regards! – jclarkw
Mike – I’m trying but not succeeding to connect my iPhone to your Flight Transfer Service. (I’ve never deliberately run a server from my computer, so the problem is likely in my understanding of the situation.) Right now I can only offer these observations:
  1. Flight Reader 1.8.43 is installed and running fine on my Windows 11 Pro system, at least to the extent that it will ingest flight logs from DJIFly that already reside on my PC.
  2. When I start your Flight Log Transfer Service, it shows the shows the screen with the QR code; and when I click the explicit link (http://192.168.0.119:5382/) there, it opens a browser window and invites me to brows my file system and select flight logs. It even imports selected logs.
  3. The Services app on the PC, says your service is set to automatic and is running. Nevertheless, the page with the QR code in Flight Reader continues to say, “Service Status: offline,” whatever that means.
  4. On my iPhone 13 Pro, if I enter the explicit link above into my Web browser of choice, Chrome, the attempted connection times out with no other errors or warnings.
  5. I do run a front end for Windows Firewall called on my PC called Windows 11 Firewall Control, but it’s not objecting to Flight Reader, nor does it even mention the service. Nothing changes when I open W11FC to all traffic.
  6. I haven’t examined your firewall rule, as I haven’t learned how to operated Windows Firewall directly.
What should I try next? – jclarkw
Most people running Windows are using Windows Defender Firewall as their firewall since it’s installed by default. When Flight Reader is installed, it creates this rule:
If that rule is missing or Windows 11 Firewall Control does not have that same rule in place, then it could be blocking port 5382. If you completely shut down all firewalls on your PC, that will at least rule out a firewall issue.
Mike – I can confirm that your Windows firewall rule is still in place and active.
Regarding shutting down Windows firewall (along with W11FC of course), I’m not keen on it since the only protection I would then have comes from an unsupported router.
Wondering if unplugging the router from the WAN (Internet) would still allow communication among LAN members… Do you happen to know?
Right, so I’m not suggesting you permanently shut down your firewalls. Just shut them down long enough to try the transfer process without them potentially blocking the needed port.
The Flight Log Transfer Service runs locally, so it’ll work whether or not an Internet connection is available. It just needs to be on the same local network as Flight Reader and any computers or devices interacting with that service.
Mike – Overnight I realized that the router runs a firewall too, and it provides a special mechanism for opening a port for incoming contact to a local PC (WAN/Virtual Server/Port Forwarding). Thus my first step was to create a rule for this in the router. This did not solve the problem.
I also found that the router seems to work just fine with the WAN port unplugged, continuing to route wireless traffic (iPhone) to local wired traffic (the PC), so in that configuration I turned off all three firewalls in the system (router, Windows Defender, and W11FC). Even in this configuration, however, the iPhone still could not connect to your server on port 5382.
Things are under control here, since I can transfer my flight logs from iPhone to PC using Apple Devices. Nevertheless, I would like to get your new service working for future simplicity. What’s the next step in debugging this?
(P.S. – I don’t know of an online external port-checker tool to confirm the hole we’ve created for the server. Suggestions?)
If you haven’t already tried temporarily disabling your firewalls or other third-party security software, I’d still recommend giving that a try. Turning them off one at a time should help narrow down which one, if any, is causing the issue.
If you’d rather troubleshoot without disabling anything, that’s certainly an option too. However, you’d be in a better position to determine the best way to do that since I’m not familiar with your local setup.
As far as I know, allowing traffic through port 5382 is the only thing that should be required.
Mike – Well I think I said above that I did turn off all three firewalls while the WAN cable was unplugged from the back of the router. But I have to admit that might not have been a “clean” test.
But there’s something else bothering me about your servrr: I don’t really understand what the address, 192.168.86.39, means. Is that the address that the service is listening to on port 5382? If so, my efforts have so far been counterproductive because of my ignorance of how servers work on a local PC…
From my iPhone I have scanned the ports around 5382 on my PC (IP address, 192.168.0.119, with all firewalls running) and found only that one port open. But perhaps I’m scanning the wrong IP address? Further, the port forwarding specification that I set for the router is 192.168.0.119:5382, not 192.168.86.39:5382 as you give in your QR code.
Do I have to open the router up to IP address 192.168.86.39 as well? Can you please straighten me out about what’s needed? – jclarkw
I just did your experiment properly – all firewalls off with the router WAN terminal connected to the Internet. (I had found that, with no WAN connection, the router did not operate properly. For example, the wired computer could not see the wired printer.) I still could not reach your server from the iPhone. Here’s what I know right now:
  1. I have a port scanner on my iPhone (“Network Analyzer,” by Technet – Free, not Pro). It reports that all the expected devices are on its LAN.
  2. With all firewalls off, it still does not see your server, 192.168.86.39, on the LAN. Not sure how this can be!
Here’s what I still don’t know:
  1. Exactly how your new firewall rule works. In other words, what must the rule I add to the router’s firewall look like?
  2. Do I guess correctly that it should open port 5382 on IP 192.168.86.39 to the internet? In that case, I know that it won’t get through the router, not just it’s firewall but my DHCP address assignments. (I have exactly enough DHCP slots open for the devices expected to be on the LAN, as identified by their know MAC addresses. That list includes my PC and the iPhone, of course, but it does not include192.168.86.39. Nor can I imagine how to specify your server by for this list, since I presume your service has no MAC address. I might be able to assign it as a fixed IP outside the DHCP range…
    Obviously I don’t know how local servers interact with DHCP and router firewalls… – jclarkw
The Flight Log Transfer Service runs locally on the computer where Flight Reader is installed. It’s not accessible from the Internet, so your iPhone will need to be connected to the same local network as the computer running the service.
From that computer, or any other device connected to the same local network, you should be able to ping the service as shown below to confirm it’s running and accessible:
Once you’ve confirmed the service is running, you’ll need to make sure any firewalls on that computer are allowing other devices on your local network to connect through port 5382.
The easiest way to rule out a firewall issue would be to temporarily disable all firewalls on that computer and try connecting again. If that works, you’ll know a firewall is blocking the connection, and you can then figure out which one needs to be configured to allow access through port 5382.
The service is running, according to Services, but not according to Flight Reader/Transfer Service, which reports it “Offline.” This would seem to be your problem, not mine. Not so?
The PC cannot ping 192.168.86.39, but it can ping itself (192.168.0.119), my wired printer (192.168.0.116), and other stuff on the LAN. So can my iPhone. What does that mean?
As reported in my previous message, I did try turning off all three firewalls and still could not connect to your service from my iPhone, which is on the LAN. Right now I’m trying to find out what other barriers in the router affect things connected on the LAN,
This means the service is running, but the local web server it attempts to run is not running.
What do you see in the most recent log file here?
C:\Program Files (x86)\Flight Reader\Services\FlightLogTransfer\logs
[10/26/2026 09:59:06 AM] Starting local web server…
[10/26/2026 09:59:06 AM] Local web server started at “http://192.168.0.119:5382”.
[10/26/2026 11:56:49 AM] Transferred flight log to “C:\Users\JCWAdministrator\Documents\FlightReader\Repository\DJIFlightRecord_2025-07-04_[16-32-28].txt”.
Is a new log file created when you manually restart Flight Reader Flight Log Transfer Service from Windows Services? The log file should be named with today’s date.
…And of course I can connect to http://192.168.0.119:5382 from my iPhone! Problem solved? – jclarkw
Yes:
[10/30/2026 01:00:31 PM] Starting local web server…
[10/30/2026 01:00:31 PM] Local web server started at “http://192.168.0.119:5382”.
But there still seem to be some problems:
I can apparently run your server from my phone, select files from the expected location, and upload them, but they don’t appear in Flight Reader’s list of imported records.
Worse yet perhaps, the window that opens when I select Flight Log Transfer service now shows my PC’s local IP, not the expected 192.168.86.39, and the service status still reports “offline.”
If you check that updated log file, does it show where the flight logs are being transferred? They be transferred to the flight log repository folder.
