Got some yarn(green color)stuck on one of my propellers while on flight, it did not crash, managed to land it but one of the motors got stuck with yarn. I managed to removed almost all of it on top but the ones below the motor cant be reached. It flies fine though after removing all the yarn. Im just worried if the ones below it would cause problems in the future. Any solution for this? Rather then sending it back to dji? I was thinking of torching it quickly to dissolve the yarn or just leave it as it does not affect my flight. Thanks for your suggestions
If those are your only two options, I’d recommend just leaving it. Using a flame could damage the motor windings and probably won’t remove all traces of the yarn anyway.
If you can still see some yarn and have a pair of sharp tweezers, you might try carefully removing anything that’s loose. Just be sure not to do anything that could damage the motor windings in the process.
Yeah, i think ill just leave it there. Tried ordering very thin tweezers but it still cant reach the gap between the coils
