As a Returning New Drone Pilot, there are a couple of Legal Things you may need to do…
You wrote that you renewed your “license” so I do not know what license needs renewing within an 18-month period, perhaps you are not located in the USA. In the USA, a TRUST Certificate does not expire and a Pat 107 Certification is valid for 24-months and only has to be made “re-current” with a FREE short test…
If you have installed the Larger, Extended Range Battery, It increases the weight of the Mini 3 Pro over the 250-gram weight and it would then be required to be registered.
If you are not located in the United Sates, then you would have your counties’ rules and laws to uphold…
If you are in the USA, then this is a link to the TRUST Certificate at the Pilot Institute Web Site (FREE…)
And again, if you are in the USA, here is the link to the FAADroneZone (Optional Registration for Drones under 250-Grams…)
In the posting by @msinger, he has given you a great lead of advice and my posting (mostly a boilerplate…) repeats some of his advice and offers some more…
So, even though you have already been told some of this previously, it’s still some Good Old Fashion Advice…
Now, here is the most important advice, STOP and take a few deep breaths, let the nerves calm down, your drones not going anywhere, just look at it and enjoy it for a moment, once you start moving it, it gets all types of new excitement because the memory of your last one winding up in a tree will flash back and you need to relax…
You should establish a routine when you fly. If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you’ll fly the drone long past it Low Battery point and when it engages Return to Home and lands in the pond or in a tree; it will be all on you…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
