So when I was trying to fly inside of the workshop and I’m literally 3’ below the drone I get an error and the drone connection for video stops.
If I go outside it works perfectly.
Indoor a metal workshop with welders and such and I’m close to vehicles so I don’t know if that makes any difference other than the magnetic field.
Flying in visual mode to Atti mode as there’s no gps signal inside the building.
When the video stops working, I can still control the drone but just don’t have any video.
An error for the IMC calibration shows up on the screen and a message to not run the drone until the calibration is complete was the last code it gave.
No, when I’m in my shop I fly without ever discovering this issue. Was at a customers shop and literally 2 minutes into it it was all over… Never could keep the connection between the controller and the drone.
When I went through the DJI app on my phone (while connected to the controller) it said I had an IMU error but it would not calibrate.
Walk on the other side of the door, outside, and it’s all good? IMU wouldn’t just come and go…
The IMU issue is probably unrelated. I’m not sure why that message would appear.
If you want to get to the bottom of this, you’ll need to revisit that shop and try flying again. If the same thing happens, then you’ll need to hunt down the source of the interference. It’s most likely coming from some type of electronic device.
