USB - C CHARGING PORT
Hi,
I have damaged the USB-C port on Dji mini 3 pro.
It needs replacing and I have found a local shop to repair it no worries but I have to sort the new charging port for the drone.
When I look online for replacement USB-C ports there are sooo many different sorts.
Does anyone know what USB- C PORT is in the mini pro 3 drone so I can purchase and have repair done asap?
Thanks for your help, much appreciated
Rach
You did not mentioned how long you’ve had your drone, but it might be covered by the warranty (only a possibility…) and have you contacted DJI Support and asked for an estimate? If they do the work, it just might re-activate a warranty…
