I’ve compiled a list of the top Spark accessories for May 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Spark owners are buying and using.
DJI Spark Battery
Notable features:
- Guaranteed to work well with your Spark since the battery is an OEM DJI accessory
Notable features:
Notable features:
- Folds closed for storage
Notable features:
DACCKIT Carrying Case
Notable features:
- Tough and durable hard outer shell
- Can hold the Spark, remote controller, 5 batteries, charger, charging hub, and other small accessories
AxPower OTG Cable
Notable features:
- Connect mobile device to the Micro USB port on the bottom of the remote controller
- Allows Wi-Fi to be disabled on mobile device to prevent possible interference
KINBON Landing Pad
Notable features:
- 30 inches wide
Kuuqa Accessories Kit
Notable features:
- Protect the remote controller sticks while in storage with the remote controller stick protector
- Lock the gimbal in place and protect the camera with the gimbal lock and cover
- Protect the props when in flight with the prop guard
- Shield the camera from the sun and protect the camera with the lens hood
- Protect your fingers when hand catching with the finger guard
LEOBRO Accessory Kit
Notable features:
Notable features:
Deyard Carrying Case
Notable features:
- Portable and lightweight
- Hard outer shell to protect the contents
- Can hold the Spark, remote controller, 3 batteries, charger, and other small accessories
DJI Spark Prop Guard
Notable features:
- Prevent the props from making contact with people or objects mid-flight
- Guaranteed to work well with your Spark since the prop guard is an OEM DJI accessory
RCstyle Parallel Battery Charger
Notable features:
- Charges 4 batteries simultaneously in about 60 minutes
- Able to also charge 2 USB devices
- Can also be powered via a car cigarette lighter charger
RCGEEK Foldable Tablet/Phone Mount
Notable features:
- Made of aluminum alloy
- Able to hold a phone or tablet
- Adjustable to customize viewing angle
- Foldable design for convenient storage
SKYREAT Extended Tablet/Phone Mount
Notable features:
- Adjustable height and position
PGYTECH Foldable Tablet/Phone Mount
Notable features:
- Made of aviation CNC aluminum
Yx Parallel Battery Charger
Notable features:
RCGEEK Battery Charger
Notable features:
- Charges 1 battery in 90 minutes
Hermitshell Remote Controller Case
Notable features:
- Hard outer shell
- Keep the sticks attached while transporting or storing the remote controller
- Protects the remote controller and prevents it from being scratched
Fstop Labs Extended Landing Gear
Notable features:
- Extends the landing gear by 1.5 inches
- Wider stance makes landings more stable
- Easy to snap on and remove
