I’ve compiled a list of the top Spark accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Spark owners are buying and using.
Notable features:
DJI Spark Battery
Notable features:
- Guaranteed to work well with your Spark since the battery is an OEM DJI accessory
Notable features:
- Folds closed for storage
Notable features:
DJI Spark Props
Notable features:
- Guaranteed to work well with your Spark since the props are an OEM DJI accessory
DACCKIT Carrying Case
Notable features:
- Tough and durable hard outer shell
- Can hold the Spark, remote controller, 5 batteries, charger, charging hub, and other small accessories
Kuuqa Accessories Kit
Notable features:
- Protect the remote controller sticks while in storage with the remote controller stick protector
- Lock the gimbal in place and protect the camera with the gimbal lock and cover
- Protect the props when in flight with the prop guard
- Shield the camera from the sun and protect the camera with the lens hood
- Protect your fingers when hand catching with the finger guard
DJI Spark Prop Guard
Notable features:
- Prevent the props from making contact with people or objects mid-flight
- Guaranteed to work well with your Spark since the prop guard is an OEM DJI accessory
Notable features:
Deyard Carrying Case
Notable features:
- Portable and lightweight
- Hard outer shell to protect the contents
- Can hold the Spark, remote controller, 3 batteries, charger, and other small accessories
LEOBRO Accessory Kit
Notable features:
PGYTECH Tablet/Phone Mount
Notable features:
- Swivels on a ball joint to adjust the angle of the mobile device
- Quick-release thumb screw allows you to attach and remove the mount quickly
Notable features:
DJI Portable Charging Station
Notable features:
- Recharge your Spark batteries out in the field with this 5000 mAh rechargeable battery station
- Charges up to three Spark batteries in 2.5 hours
- Recharge the charging station in 1.5 hours
SKYREAT Extended Tablet/Phone Mount
Notable features:
- Adjustable height and position
RC GearPro Battery Charging Hub
Notable features:
- Charges 4 batteries at the same time
- Recharge 4 batteries in 70 minutes
HeiyRC Accessory Kit
Notable features:
- Prop mount bracket holds the props in place and protects them while in storage
Yx Parallel Battery Charger
Notable features:
- Charges 4 batteries simultaneously in about 60 minutes
- Able to also charge 2 USB devices
Want to check out more Spark accessories? A commonly used list of Spark accessories sorted by category is available at Spark-Help.com.
