I’ve compiled a list of the top Phantom 4 accessories for May 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Phantom 4 owners are buying and using.
Fstop Labs Landing Pad
Notable features:
- 30 inches wide
SanDisk 64GB Micro SD Memory Card
Notable features:
- U3 memory card
- Fast enough to record any type of photos/video produced by the Phantom 4
- Transfer files to/from the memory card with the included memory card reader
DJI High Capacity Phantom 4 Battery
Notable features:
- Guaranteed to work well with your Phantom since the battery is an OEM DJI accessory
HUL Aluminum Carrying Case
Notable features:
- Aluminum frame construction with ABS plastic panels
- Can store the Phantom with the props attached
DJI Goggles
Notable features:
- Dual 1920 x 1080 HD screens
- Integrated touchpad to navigate through menus within the goggles
- HDMI input and 3.5mm audio jack
- Up to 6 hours of battery life
More details can be found here on Amazon or here in the DJI Store. And if you want to save a few bucks, you can purchase refurbished DJI goggles here.
PGYTECH Drone Landing Pad
Notable features:
- 20 inches wide
- Weighted to keep it in place in windy conditions
DJI Props
Notable features:
- Guaranteed to work well with your Phantom since the props are an OEM DJI accessory
- Slightly quieter prop noise
Yx Parallel Battery Charger
Notable features:
- Charges 3 batteries simultaneously in about 80 minutes
- Able to charge the remote controller
- Anodized aluminum case offers a non-conductive layer
- Ground earth connection for safety
DJI Low-Noise Props
Notable features:
Hooshion Lanyard
Notable features:
- Made of high tenacity nylon
- Adjustable length
RCGEEK Tablet Sunshade
Notable features:
- Shades your mobile device screen from sunlight
- Folds up for easy storage
- Small magnets hold the sunshade closed when folded
DJI HDMI Output Module
Notable features:
- Output 720p live HD video stream to an HDMI device
- Commonly used to display video on goggles or a second screen
- Includes Mini-HDMI output port, Micro-USB port, USB port, and a CAN expansion port
DJI Car Battery Charger
Notable features:
Ultimaxx Backpack
Notable features:
- High quality water resistant nylon exterior
- High density EVA foam interior to shield your gear from impact-related damage
- Can hold the Phantom, remote controller, 3 batteries, charger, and other small accessories
DJI Prop Guards
Notable features:
- Guaranteed to work well with your Phantom 4 since the guard is an OEM DJI accessory
- See them in action here
DJI Battery Charging Hub
Notable features:
- Charges three batteries (one at a time) in 3.5 hours
- Toggle the switch to discharge batteries down to the storage level
- Connects to power cable from the OEM DJI battery charger
UAV Blue Tablet Sun Shade
Notable features:
- Made from injection molded ABS plastic
- Sides and top can be folded over the tablet to protect it when not in use
Powerextra Parallel Battery Charger
Notable features:
RCGEEK Phone Sunshade
Notable features:
- Shades your mobile phone screen from sunlight
