I’ve compiled a list of the top Phantom 4 accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Phantom 4 owners are buying and using.
Fstop Labs Landing Pad
Notable features:
- 30 inches wide
DJI High Capacity Phantom 4 Battery
Notable features:
- Guaranteed to work well with your Phantom since the battery is an OEM DJI accessory
ENGPOW Fireproof Lipo Bag
Notable features:
- Made of silicon coated fiberglass with heat blocking aluminum foil inside
- Large enough to hold multiple Phantom batteries
- Keeps batteries safe while charging, traveling, and storing
HUL Aluminium Carrying Case
Notable features:
- Aluminum frame construction with ABS plastic panels
- Can store the Phantom with the props attached
PGYTECH Drone Landing Pad
Notable features:
- 20 inches wide
- Weighted to keep it in place in windy conditions
DJI Low-Noise Props
Notable features:
- Guaranteed to work well with your Phantom since the props are an OEM DJI accessory
- Slightly quieter prop noise
Yx Parallel Battery Charger
Notable features:
- Charges 3 batteries simultaneously in about 80 minutes
- Able to charge the remote controller
- Anodized aluminum case offers a non-conductive layer
- Ground earth connection for safety
DJI Goggles
Notable features:
- Dual 1920 x 1080 HD screens
- Integrated touchpad to navigate through menus within the goggles
- HDMI input and 3.5mm audio jack
- Up to 6 hours of battery life
More details can be found here on Amazon or here in the DJI Store. And if you want to save a few bucks, you can purchase refurbished DJI goggles here.
Hooshion Lanyard
Notable features:
- Made of high tenacity nylon
- Adjustable length
DJI HDMI Output Module
Notable features:
- Output 720p live HD video stream to an HDMI device
- Commonly used to display video on goggles or a second screen
- Includes Mini-HDMI output port, Micro-USB port, USB port, and a CAN expansion port
Ultimaxx Backpack
Notable features:
- High quality water resistant nylon exterior
- High density EVA foam interior to shield your gear from impact-related damage
- Can hold the Phantom, remote controller, 3 batteries, charger, and other small accessories
Powerextra Backpack
Notable features:
- Hard exterior shell and EVA to protect the contents
- Padded and breathable mesh back panel for comfort when carrying on your back
- Small enough to fit in an airplane overhead bin
Hooshion Antenna Range Extender
Notable features:
- Folds closed for storage
RCGEEK Tablet Mount Extender
Notable features:
- Extends the remote controller mount to allow larger 10 inch tablets to be used
- Solid plastic design (not 3D printed)
RCGEEK Sunshade
Notable features:
- Shades your mobile device screen from sunlight
- Folds up for easy storage
- Small magnets hold the sunshade closed when folded
DJI Sunshade
Notable features:
- Collapsible and easy to carry
DJI Remote Controller Strap
Notable features:
- Off-load the weight of the remote controller when flying for long periods of time
- Adjustable straps
- Store in the included storage bag
Want to check out more Phantom accessories? A commonly used list of Phantom accessories sorted by category is available at PhantomHelp.com.
