I’ve compiled a list of the top Mavic Pro accessories for May 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Pro owners are buying and using.
Notable features:
KINBON Landing Pad
Notable features:
- 30 inches wide
Notable features:
- Folds closed for storage
Fstop Labs Foldable Tablet/Phone Mount
Notable features:
Smatree Mavic Pro Carrying Case
Notable features:
- Made of high-density EVA material
- Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
SanDisk 64GB Micro SD Memory Card
Notable features:
- U3 memory card
- Fast enough to record any type of photos/video produced by the Mavic Pro
- Transfer files to/from the memory card with the included memory card reader
Smatree Battery Charger
Notable features:
- Charges 3 batteries (one at a time) in about 140 minutes
- Charges faster than the OEM DJI battery charger
- USB port can be used to charge the remote controller or a mobile device
DJI Mavic Pro Low-Noise Props
Notable features:
- Guaranteed to work well with your Mavic Pro since the props are an OEM DJI accessory
- Slightly quieter prop noise
- Slightly increased flight time
Arzoic Gimbal Lock & Camera Cover
Notable features:
- Single piece that both locks the gimbal in place and covers the camera to protect it
- Made of high-impact plastic
- Easier to attach than the OEM lock and cover
Notable features:
Fstop Labs Battery Charging Hub
Notable features:
- Charges 4 batteries one at a time
- 60-80 minute charge time per battery
- Connects to OEM DJI car charger or power cable from the OEM DJI battery charger
- Display shows the charge voltage, charge current, and overall battery status
DJI Mavic Pro Battery
Notable features:
- Guaranteed to work well with your Mavic Pro since the battery is an OEM DJI accessory
AxPower Accessory Pack
Notable features:
- Protect the remote controller sticks and screen while in storage with the remote controller stick protector
- Lock the gimbal in place and protect the camera with the gimbal lock and cover
- Shield the camera from the sun and protect the camera with the lens hood
- Protect the motors while in storage with the silicone motor caps
- Add 1.2 inches to the landing gear with the extended landing gear
- Keep the props folded in place while in storage with the prop straps
RCGEEK Foldable Tablet/Phone Mount
Notable features:
- Made of aluminum alloy
- Able to hold a phone or tablet
- Adjustable to customize viewing angle
- Foldable design for convenient storage
CamKix Accessory Pack
Notable features:
- Protect the remote controller sticks while in storage with the remote controller stick protector
- Keep the props folded in place while in storage with the prop locks
SKYREAT Extended Tablet/Phone Mount
Notable features:
- Adjustable height and position
Arzroic Lens Hood
Notable features:
- Reduces sun glare when taking photos
- Shields the camera from the sun and helps protect the camera and gimbal
- Designed to stay out of the camera view (even when flying in sport mode)
PGYTECH Foldable Tablet/Phone Mount
Notable features:
- Made of aviation CNC aluminum
DACCKIT Mavic Pro Carrying Case
Notable features:
- Hard outer shell is tough, durable, and waterproof
- Inside of the case is lined with a soft microfiber material
- Can hold the Mavic, remote controller, 5 batteries, charger, charging hub, and other small accessories
DJI Goggles
Notable features:
- Dual 1920 x 1080 HD screens
- Integrated touchpad to navigate through menus within the goggles
- HDMI input and 3.5mm audio jack
- Up to 6 hours of battery life
More details can be found here on Amazon or here in the DJI Store. And if you want to save a few bucks, you can purchase refurbished DJI goggles here.
