I’ve compiled a list of the top Mavic Pro accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Pro owners are buying and using.
Notable features:
Homga Landing Pad
Notable features:
- 30 inches wide
Notable features:
- Folds closed for storage
Notable features:
DJI Mavic Pro Low-Noise Props
Notable features:
- Guaranteed to work well with your Mavic Pro since the props are an OEM DJI accessory
- Slightly quieter prop noise
- Slightly increased flight time
DJI Mavic Pro Props
Notable features:
SanDisk 64GB Micro SD Memory Card
Notable features:
- U3 memory card
- Fast enough to record any type of photos/video produced by the Mavic 2
- Transfer files to/from the memory card with the included memory card reader
Smatree Battery Charger
Notable features:
- Charges 3 batteries (one at a time) in about 140 minutes
- Charges faster than the OEM DJI battery charger
- USB port can be used to charge the remote controller or a mobile device
Smatree Mavic Pro Carrying Case
Notable features:
- Made of high-density EVA material
- Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
Wrapgrade Mono Skin for Mavic Pro Remote Controller
Notable features:
- Made with 3M’s finest double cast vinyl
- Unique design pattern without corner gaps
- Comes with detailed installation instructions
Aterox Gimbal Lock & Camera Cover
Notable features:
- Single piece that both locks the gimbal in place and covers the camera to protect it
- Made of high-impact plastic
- Easier to attach than the OEM lock and cover
Powerextra Mavic Pro Battery
Notable features:
- Comparable performance to the OEM DJI Mavic Pro battery
- Compatible with all Mavic Pro battery accessories
- The best 3rd party battery replacement if you’re looking for something other than OEM DJI batteries
Notable features:
Fstop Labs Battery Charging Hub
Notable features:
- Charges 4 batteries one at a time
- 60-80 minute charge time per battery
- Connects to OEM DJI car charger or power cable from the OEM DJI battery charger
- Display shows the charge voltage, charge current, and overall battery status
Arzroic Lens Hood
Notable features:
- Reduces sun glare when taking photos
- Shields the camera from the sun and helps protect the camera and gimbal
- Designed to stay out of the camera view (even when flying in sport mode)
Notable features:
SKYREAT Extended Tablet/Phone Mount
Notable features:
- Adjustable height and position
Want to check out more Mavic Pro accessories? A commonly used list of Mavic Pro accessories sorted by category is available at MavicHelp.com.
