I’ve compiled a list of the top Mavic Air accessories for May 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Air owners are buying and using.
Notable features:
Notable features:
- Folds closed for storage
DJI Mavic Air Battery
Notable features:
- Guaranteed to work well with your Mavic Air since the battery is an OEM DJI accessory
Notable features:
DJI Mavic Air Props
Notable features:
- Guaranteed to work well with your Mavic Air since the props are an OEM DJI accessory
Fstop Labs Landing Pad
Notable features:
- 30 inches wide
Notable features:
RLSOCO Carrying Case
Notable features:
- Tough and durable outer shell
- Corners and sides of case are reinforced to protect contents
- Can hold the Mavic Air, remote controller, 4 batteries, charger, and other small accessories
- Mesh pocket in lid for additional storage
RCGEEK Foldable Tablet/Phone Mount
Notable features:
- Made of aluminum alloy
- Able to hold a phone or tablet
- Adjustable to customize viewing angle
- Foldable design for convenient storage
SKYREAT Extended Tablet/Phone Mount
Notable features:
- Adjustable height and position
Drone Pit Stop Carrying Case
Notable features:
- Hard outer shell
PGYTECH Foldable Tablet/Phone Mount
Notable features:
- Made of aviation CNC aluminum
Yx Battery Charging Hub
Notable features:
- Charges 4 batteries (one at a time) in 3.5 hours
- Connects to power cable from the OEM DJI battery charger
Arzroic Extended Landing Gear
Notable features:
- Elevates for extra clearance and stabilizes the landing gear
- A clasp secures each extended leg to the Mavic Air arms
- Made from a strong, mold injected plastic
Smatree Carrying Case
Notable features:
- Hard outer shell
- Can hold the Mavic Air, remote controller, 4 batteries, charger, charging hub, and other small accessories
DACCKIT Carrying Case
Notable features:
- Tough and durable hard outer shell
- Interior is lined with a soft microfiber material
- Can hold the Mavic Air, remote controller, 5 batteries, charger, charging hub, and other small accessories
SanDisk 64GB Micro SD Memory Card
Notable features:
- U3 memory card
- Fast enough to record any type of photos/video produced by the Mavic Air
- Transfer files to/from the memory card with the included memory card reader
DJI Battery Charging Hub
Notable features:
Oumers Carrying Case
Notable features:
- Hard waterproof outer shell
- Carry with side carry handle
PolarPro Cinema Series Filters
Notable features:
- ND32, ND32/PL, ND64, and ND64/PL filters
- Production grade multi-coated glass for best optical performance
- Lightweight airframe aluminum construction
- Store the filters in the included hard case
- Lifetime warranty
