I’ve compiled a list of the top Mavic Air accessories for June 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Air owners are buying and using.
Notable features:
Notable features:
Notable features:
- Folds closed for storage
DJI Mavic Air Battery
Notable features:
- Guaranteed to work well with your Mavic Air since the battery is an OEM DJI accessory
DJI Mavic Air Props
Notable features:
- Guaranteed to work well with your Mavic Air since the props are an OEM DJI accessory
Fstop Labs Landing Pad
Notable features:
- 30 inches wide
Notable features:
Notable features:
RLSOCO Carrying Case
Notable features:
- Tough and durable outer shell
- Corners and sides of case are reinforced to protect contents
- Can hold the Mavic Air, remote controller, 4 batteries, charger, and other small accessories
- Mesh pocket in lid for additional storage
Yx Battery Charging Hub
Notable features:
- Charges 4 batteries (one at a time) in 3.5 hours
- Connects to power cable from the OEM DJI battery charger
PGYTECH Tablet/Phone Mount
Notable features:
- Swivels on a ball joint to adjust the angle of the mobile device
- Quick-release thumb screw allows you to attach and remove the mount quickly
Fstop Labs Battery Car Charger
Notable features:
- Simultaneously charge two Mavic Air batteries in 40-60 minutes
- USB port can be used to charge the remote controller or a mobile device
Smatree Carrying Case
Notable features:
- Hard outer shell
- Can hold the Mavic Air, remote controller, 4 batteries, charger, charging hub, and other small accessories
Arzroic Extended Landing Gear
Notable features:
- Elevates for extra clearance and stabilizes the landing gear
- A clasp secures each extended leg to the Mavic Air arms
- Made from a strong, mold injected plastic
RCGEEK Foldable Tablet/Phone Mount
Notable features:
- Made of aluminum alloy
- Able to hold a phone or tablet
- Adjustable to customize viewing angle
- Foldable design for convenient storage
Powerextra Foldable Tablet/Phone Mount
Notable features:
- Mounts mobile device above the remote controller so it doesn’t block the remote controller sticks and screen
- Hole at base to attach included lanyard
Hermitshell Remote Controller Case
Notable features:
- Protect the remote controller from bumps and scratches
- Keep the remote controller sticks attached while in storage
Techfection Adjustable Tablet/Phone Mount
Notable features:
- Tilts up to 45 degrees up or down
- Use the thumb screw to quickly adjust the mount and lock it into place
Hoodman Landing Pad
Notable features:
- 3 or 5 feet wide
- Weighted perimeter to keep landing pad in place without stakes
DJI Battery Charging Hub
Notable features:
