I’ve compiled a list of the top Mavic Air accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic Air owners are buying and using.
Notable features:
Notable features:
Wrapgrade Poly Skin for Mavic Air
Notable features:
- Made with 3M’s finest double cast vinyl
- Unique design pattern without corner gaps
- Comes with detailed installation instructions
DACCKIT Carrying Case
Notable features:
- Tough and durable hard outer shell
- Interior is lined with a soft microfiber material
- Can hold the Mavic Air, remote controller, 5 batteries, charger, charging hub, and other small accessories
DJI Mavic Air Props
Notable features:
- Guaranteed to work well with your Mavic Air since the props are an OEM DJI accessory
DJI Mavic Air Battery
Notable features:
- Guaranteed to work well with your Mavic Air since the battery is an OEM DJI accessory
Fstop Labs Battery Car Charger
Notable features:
- Simultaneously charge two Mavic Air batteries in 40-60 minutes
- USB port can be used to charge the remote controller or a mobile device
Notable features:
Notable features:
Yx Battery Charging Hub
Notable features:
- Charges 4 batteries one at a time
- 60-80 minute charge time per batter
- Connects to power cable from the OEM DJI battery charger
PGYTECH Tablet/Phone Mount
Notable features:
- Swivels on a ball joint to adjust the angle of the mobile device
- Quick-release thumb screw allows you to attach and remove the mount quickly
RLSOCO Carrying Case
Notable features:
- Tough and durable outer shell
- Corners and sides of case are reinforced to protect contents
- Can hold the Mavic Air, remote controller, 4 batteries, charger, mobile device, and other small accessories
SKYREAT Extended Tablet/Phone Mount
Notable features:
- Adjustable height and position
RCGEEK Tablet/Phone Mount
Notable features:
- Aluminum alloy bracket & shaft securely locks the mobile device into place
- Fordable design for easy storage and transport
- Holes at base to attach the included lanyard
Arzroic Extended Landing Gear
Notable features:
- Elevates for extra clearance and stabilizes the landing gear
- A clasp secures each extended leg to the Mavic Air arms
- Made from a strong, mold injected plastic
HolaFoto Carrying Case
Notable features:
- Shock absorbent foam interior
- Can hold the Mavic Air, remote controller, 4 batteries, charger, charging hub, and other small accessories
Yx Parallel Battery Charger
Notable features:
- Charges 4 batteries simultaneously in about 60 minutes
- Able to also charge 2 USB devices
- Covers protect charger terminals when not in use
SunnyLife Fireproof LiPo Battery Bags
Notable features:
- Made from PVC flame retardant cloth
- Keeps batteries safe while charging, traveling, and storing
Want to check out more Mavic Air accessories? A commonly used list of Mavic Air accessories sorted by category is available at MavicHelp.com.
