I’ve compiled a list of the top Mavic 2 accessories for June 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic 2 owners are buying and using.
Notable features:
Notable features:
DJI Mavic 2 Battery
Notable features:
- Guaranteed to work well with your Mavic 2 since the battery is an OEM DJI accessory
Notable features:
- Folds closed for storage
DJI Low-Noise Props
Notable features:
- Guaranteed to work well with your Mavic 2 since the props are an OEM DJI accessory
DJI Mavic 2 Fly More Kit
Notable features:
- Includes a full set of props, two batteries, power bank adapter, car charger, and battery charging hub
- Guaranteed to work well with your Mavic 2 since they are OEM DJI accessories
PGYTECH Prop Holder
Notable features:
- Holds and protects the props during storage
- Made of flexible silicone material
- Easy to install and remove
Smatree Mavic 2 Carrying Case
Notable features:
- Made Of High-density EVA material
- Tough and durable outer case
- Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
DACCKIT Carrying Case
Notable features:
- Tough and durable outer shell
- Can hold the Mavic, remote controller, 5 batteries, charger, charging hub, and other small accessories
Fstop Labs Landing Pad
Notable features:
- 30 inches wide
Notable features:
Fstop Labs Parallel Battery Charger
Notable features:
- Can charge 3 batteries simultaneously in 60 minutes
- Able to also charge 2 USB devices
- Comes with a 3 prong cable with ground
- Charger is internally grounded for safety
- Outer shell made of anodized aluminum alloy to help dissipate heat
Notable features:
ENGPOW Fireproof LiPo Bag
Notable features:
- Made of silicon coated fiberglass with heat blocking aluminum foil inside
- Large enough to hold multiple Mavic batteries
- Keeps batteries safe while charging, traveling, and storing
Notable features:
PGYTECH Foldable Tablet/Phone Mount
Notable features:
- Made of aviation CNC aluminum
- Foldable design for convenient storage
PGYTECH Extended Landing Gear
Notable features:
- Extends the landing gear by about 1.4 inches
- Made by high quality ABS & silica plastic
Fstop Labs Carrying Case Set
Notable features:
- Separate hardshell cases to protect the Mavic and remote controller
- Water resistant exterior shell
SunnyLife Parallel Car Battery Charger
Notable features:
- Charges two Mavic 2 batteries in about 60 minutes
- Able to also charge Mavic 2 remote controller or another USB device
Notable features:
DJI Mavic 2 Battery
Notable features:
Notable features:
DJI Low-Noise Props
Notable features:
Notable features:
PGYTECH Prop Holder
Notable features:
Notable features:
Notable features:
Notable features:
- 30 inches wide
Notable features:
Notable features:
Notable features:
Notable features:
Notable features:
Notable features:
Notable features:
Notable features:
Notable features:
