I’ve compiled a list of the top Mavic 2 accessories for April 2019. These accessories were chosen based on their sales volume on Amazon over the past month. If you’re looking for some new accessories to add to your kit, this list will give you an idea of what other Mavic 2 owners are buying and using.
Notable features:
Homga Landing Pad
Notable features:
- 30 inches wide
Notable features:
- Folds closed for storage
Notable features:
DJI Low-Noise Props
Notable features:
- Guaranteed to work well with your Mavic 2 since the props are an OEM DJI accessory
Fstop Labs Accessory Bundle
Notable features:
- Protect the remote controller sticks & screen from damage when storing/transporting your remote controller
- Extended landing gear will raise your Mavic 2 off the ground for extra clearance
- Lens hood will shield the camera from the sun and help protect the camera
Fstop Labs Mavic 2 Pro ND Filters
Notable features:
- Includes an ND4, ND8, and ND16 filter
- Aircraft grade 6061 anodized aluminium frame
- Sharp AGC glass made in Japan
- Multi-coated to reduce ghosting, lens flare, and improve image quality
- Sawtooth ridges on the sides make the filters easy to grip
- Filters come in a padded, rigid carrying case
DJI Mavic 2 Battery
Notable features:
- Guaranteed to work well with your Mavic 2 since the battery is an OEM DJI accessory
SanDisk 64GB Micro SD Memory Card
Notable features:
- U3 memory card
- Fast enough to record any type of photos/video produced by the Mavic 2
- Transfer files to/from the memory card with the included memory card reader
PGYTECH Prop Holder
Notable features:
- Holds and protects the props during storage
- Made of flexible silicone material
- Easy to install and remove
DJI Prop Guard
Notable features:
- Guaranteed to work well with your Mavic 2 since the guard is an OEM DJI accessory
DJI Mavic 2 Fly More Kit
Notable features:
- Includes a full set of props, two batteries, power bank adapter, car charger, and battery charging hub
- Guaranteed to work well with your Mavic 2 since they are OEM DJI accessories
PolarPro CrystalSky Mount
Notable features:
- Securely mounts your CrystalSky to your Mavic 2 remote controller
- Rigid frame design is over-engineered to eliminate any flexing while flying
- Lightweight aluminum construction is built to endure your rugged adventures
- Ergonomic grip is tapered to fit perfectly in your hands
Notable features:
SanDisk 128GB Micro SD Memory Card
Notable features:
- U3 memory card
- Transfer files to/from the memory card with the included USB 3.0 memory card reader
Smatree Mavic 2 Carrying Case
Notable features:
- Made Of High-density EVA material
- Tough and durable outer case
- Can hold the Mavic, remote controller, 4 batteries, charger, and other small accessories
Notable features:
DACCKIT Carrying Case
Notable features:
- Tough and durable outer shell
- Can hold the Mavic, remote controller, 5 batteries, charger, charging hub, and other small accessories
Fstop Labs Parallel Battery Charger
Notable features:
- Can charge 3 batteries simultaneously in 60 minutes
- Able to also charge 2 USB devices
- Comes with a 3 prong cable with ground
- Charger is internally grounded for safety
- Outer shell made of anodized aluminum alloy to help dissipate heat
Fstop Labs Carrying Case Set
Notable features:
- Separate hardshell cases to protect the Mavic and remote controller
- Water resistant exterior shell
Want to check out more Mavic 2 accessories? A commonly used list of Mavic 2 accessories sorted by category is available at MavicHelp.com.
