the graphical vision on the data fields
Hello
From the CSV file extracted from FlyReader
I wrote a Matlab script that allows you to display graphs.
It’s very interesting to see certain parameters such as the intensity, which will play a lot on the autonomy of the drone.
It might be a good idea to insert the graphical vision on the data fields of different parameters like altitude, intensity consumed, horizontal or vertical speed, etc.
Flight Reader currently has a feature to generate charts (or graphs) for one or more fields from the generated aircraft log.
Can you tell me more about what you’re recommending I add?
The idea would be, on a data table, to select a column with a right click, to display the graph of the evolution of the data as a function of flight time, for example…
Those are pretty awesome graphs. How were you able to record the trails, FlyReader too?
Carlos in Texas
To make the plots I used a Matlab programming language
It opens the . CSV that is generated by FlyReader
The column of data is extracted: altitude, speed, consumption, etc…
and he plots the graph…
Here’s what that would look like if you generate the charts directly in Flight Reader:
You can find more details here:
Fantastic!
I hadn’t seen that there was this function :+1:
Well done!
