Stuck in "Resetting Gimble mode"
No matter what I do, I cannot get my Neo2 to fly.
It says, “Unable to takeoff, connect to app to see why”.
There’s a red led lit on the port side as well.
When I try Gimbal Calibration on AUTO, it sits at 0% and doesn’t move.
When I try Gimbal Calibration on MANUAL it doesn’t respond to the + or - command and if I try to ove it manually, it resists and moves to another position.
Is it new, is it old, did you just crash it, did you just drop it, did you just “bump” into a wall a little bit… When was the last time you flew it, did you just fly it, did this magically appear after it had ben put away? So many questions, so few answers… any other pertinent details that the members need to know to try to help would be helpful…
It’s not brand new, but it has less than an hour of flight time.
I didn’t crash it.
It was working fine; it landed in my hand, and the next time it gave me this error message.
OK assuming the “Hand Catch” was as gentle as you imply, here are my suggestions…
The combination of an “Unable to takeoff” error, a solid red status light, and a gimbal calibration stuck at 0% indicates that the drone’s flight controller is blocking takeoff due to a hardware-level gimbal malfunction or physical obstruction.
There may be a physical obstructions or misalignment.
1. Double-check that the plastic gimbal guard or any transport locks have been fully removed.
2. On the DJI Neo series, the camera sits in an inner cradle or “sled” suspended by rubber bands. If the drone had a minor crash or hard landing, this sled can easily pop out of its track or slide slightly forward. With the drone turned off, gently check if you need to push the camera module slightly backward or snap the cradle back into its exoskeleton frame.
3. Microscopic sand, dirt, or hair can jam the tiny 0.1mm gaps in the gimbal joints. Turn the drone off and manually move the camera through its axes. If it feels “crunchy” or tight, use a can of compressed air to clear out the joints.
4. Remove any aftermarket wide-angle lenses, heavy UV filters, or ND filters, as the extra weight will instantly cause a motor overload and freeze calibration. [1, 2, 3]
If the camera moves perfectly freely by hand while powered down, the problem may be electronic.
a. Ensure the drone is sitting on a perfectly flat, level, and non-metallic surface. If the drone detects it is tilted or vibrating, the auto-calibration sequence will refuse to advance from 0%.
b. Power on your remote controller, open the DJI Fly App, and navigate to the profile tab to check for updates. If a firmware update failed or corrupted mid-way, connect the drone to a computer using [DJI Assistant 2 to refresh or reinstall the firmware package.
After this, I am at a loss and suggest you (if you bought the repair insurance) take advantage of the insurance policy… If not, I hope the seller has a generous return/replacement policy.
Thank you for your help. I have already gone through all of the steps you mentioned before posting. Gemini AI recommended the same almost verbatim.
I have taken advantage of the insurance and will be receiving a replacement later this week.
Thanks again for your help.
Good luck to you and I hope your next one gives you years of service!
Hi Spearhead, I’ve just bought a Neo 2 from John Pye that has this exact problem, I think it’s a return from DJI. Could it be yours? :slight_smile:
The Gimbal suspension rubber is snapped, and the r motor for the camera roll is ‘seized’. Now that I’ve removed it I’m currently looking to see how to it goes together. If anyone has any ideas, I’m all ears?
I’m guessing the bell/stator is a push fit into the motor?
I used this video for disassembly of the drone https://www.youtube.com/watch?v=LUCMukPBjKM&t=1216s
:sweat_smile: It’s possible!
