Hello,
I obtain flight log csv file with https://www.phantomhelp.com/logviewer/ converter. However, when I open it with excel, some data are date type even it is not date. They are not seperated with comma as well, they are like normal xlsx format. However, if I try to read it with python and pandas, its columns are not correct.
Best regards.
Can you share an example to show what you’re describing?
@msinger you can download it from https:// www. phantomhelp .com/ logviewer/ 0Z6GZBLBXT7GY062JQUU/
When I look at latitude column, I see it as a 37589654 for example. Or when I look at altitude, I see date of today.
Note: please remove empty spaces from link, the syste does not let me to share the link.
Are you by chance using a Windows region where a comma is the decimal symbol instead of a period? If so, that would explain why 37.589654 is being treated as 37589654 when the CSV is viewed on your computer.
