Single log file remains in Repository
Hi Mike-
Thanks again for Flight Reader!
I’ve noticed for some time now that every time I paste DJI flight logs into the Repository folder (which is incidentally on Google Drive), then 1 file will always remain unprocessed. At first I thought it was just an issue with a single file, but that’s not it. The only way I can get that last flight to sync is by copy/pasting it (with a different name) or another file into the Repo.This is a repeated behavior every time I copy new files to the Repository.
Any idea what’s going on?
Thanks!
-pat
Which version of Flight Reader are you using?
v 1.6.14
I think it’s been happening for a few versions now.
Just realized I have 1.61.7 but haven’t installed it yet. I’ll try that and report back.
Hey Mike-
Just want to report that this problem still exists as of v1.7.6 (I saw 1.7.7 was released but have not flown since then).
Flight Reader says it is processing all of the logs, but only n-1 actually get added to the database and 1 remains in the repository folder. For example, if I drop 10 files in there, FR will report that it is cycling through all 10 log files (1/10, 2/10, … 10/10), but only 9 new flights will end up in the database. If I go to the Repo, there is still 1 log file left there (the missing one). If I copy the file and paste it right back in there, one of them will process and I’ll get the last log added to the database, and one file will remain, which I can then delete. As a reminder, my Flight Reader folder with Repository in on Google Drive, not local. Any thoughts?
Thanks!
Does the last log file get picked up if you restart Flight Reader?
I’m not sure but I don’t think so. I can test this next time I have some logs to process.
Cheers,
-pat
