Is there a way in the ‘Pilots’ tab to set a default name and role so that it does not have to be entered/chosen every single flight. This would be helpful as I am always the Pilot and Pilot in command.
Thanks,
Chris
Thanks,
Chris
That option is currently only available when syncing flight logs from a DJI account.
I’m not sure I understand. I assume my DJI login is my DJI account and my flight logs are automatically synced. Is there some setting I need to enable in Flight Reader?
Chris
Yep! You just need to edit your account below and choose the default Name and Role when syncing from your DJI account.
These defaults are not available when syncing/processing flight logs in other ways.
Ok thanks I’ll try that.
Chris
Thanks.
I added my details in ‘edit’ your account. Didn’t realize there was a way to do this in the sync flight logs tab.
Chris
I did 4 flights today with 3 different drones and the Pilot info filled in automatically. This saves time when loging flights.
Thanks for your help.
Chris
