Let’s discuss using the Samsung Galaxy Tab A (10.1") with DJI GO. Share tips, the best device settings, accessories used with this device, and troubleshoot problems.
Here are some tips/settings that’ll help DJI GO perform better on your Samsung Galaxy Tab A:
Remeber to turn Cache off before flying.
A bit heavy but I like it. Version in my country has 2gb RAM but seems to cope.
Flying with P4 the screen sometimes darkens by about 95% and you cannot really see anything but the screen isn’t off. Sleep mode is 5 mins so it’s not that.
What does the 80/20% relate to when referring to DJI GO in the list?
BTW for the 10.1" size I found the L220 sunshade a better fit the the 200.
All very well … except for something extremely fundamental … The power bank function of the RC remote control (function that does exist in IOS) cannot be turned off … With which (DJI always blamed this problem on Android …) Your command will last half of its useful life … It seems that those who use Android … Our money has less value … Let’s see if once and for all DJI fixes such a situation …
I love this tablet never really used it, only for movies on sd and it’s probably only had a couple apps. I’ve tried everything to get working w the mavic p1 but I lose signal easy and I get bad video. I have nearly half internal storage free with 1.2 available (given) ram and it still holds charge for days. I gave Go 4 all the flex & freedom I could no optimizing. Used Belkin and Anker cables, 128gb sdxc too… with that said one small thing…I get the device is charging slowly noti only with the controller. I don’t get that on anything else but then again don’t just plug it into anything. Saw a crazy dude plug a power bank into the controller as a fix to the android drain. I wouldn’t wanna get that extreme. Only thing would be a hard reset but the frp would suck if stuck. 3 phones and 2 phablets not a problem. Was really hoping all these years later I could put that mod deuce to use! Any ideas? Oh and tried wiping cache from bootloader and haven’t tried gpu render settings in dev options (droid 6.0 only has a few) Seems more like a power struggle. Tablet draws > MC signal cuts i/o > mc draws back > video tearing lost refresh rate. It’s kinda risky but don’t wanna give up!
Hi all. My experience (not necessarily blaming the Tab A 10.1 2016 tablet): first time I switched from smartphone (Redmi 9 Pro - flawless) to this tablet, drone went uncontrollable after a while and crashed. Tablet misconfigured? Cable? (O'woda Micro USB a Micro USB Cavo Dati OTG 29cm Intrecciato in Nylon Connettore di trasferimento Video per DJI Mavic Mini/Air/PRO/Spark/Mavic 2 ad Android Micro USB Tablet : Amazon.it: Informatica). Before crashing I managed to fly for a while but images where randomly in low res, in full res and with blu bands on them. After 5 or 10 minutes drone went uncontrolled and crashed. Thanks for your clues.
