Samsung Galaxy J7 Sky Pro (2017)
Let’s discuss using the Samsung Galaxy J7 Sky Pro with DJI GO. Share tips, the best device settings, accessories used with this device, and troubleshoot problems.
Here are some tips/settings that’ll help DJI GO perform better on your Samsung Galaxy J7 Sky Pro:
thank you for the link. I ended up here from a sparkpilot forum link.
I initially installed go app 4 and connected this phone to controller via ogb. It detected the spark but could not really use flight simulator since it would revert to the home page on its own.
I then tried same setup using an lg rebel 4 - again with only 2 GB of memory and the same thing happened. I called dji and they said device was not in their list of android supported devices (not very helpful)
So it occurred to me that maybe i needed more like 4 GB. But i see you show the sky pro in the list. So i tried the rebel 4 in gofly/camera mode and it works.
Are you able to run FS? Do you think flying with only 2 GB runs the risk the app may drop out spontaneously like it does from the FS?
thanks.
