Remote ID after firmware update
Hello,
I own a Mini 4 Pro, bought in Germany. I had activated a remote ID when the drone still had an old firmware. Since then I have updated the firmware several times. Now I have v01.00.0700.
Is the Remote ID activated back then still active after the firmware updates?
I use the standard batteries, not the Plus batteries.
Thank you!
Yes, the aircraft is still capable of enabling Remote ID after installing subsequent firmware updates.
As noted below in the Mini 4 Pro manual, Remote ID is not enabled when flying with standard batteries. You’ll need to purchase and use Plus batteries when Remote ID is needed for a flight.
Thank you.
But isn’t it the case that the remote ID I activated back then is out of function until I insert the Plus batteries? Or does it continue to transmit implicitly and can be read out?
You cannot manually activate Remote ID on the Mini 4 Pro. Remote ID will only be activated if you power on the drone with a Plus battery inserted.
