Both of my forward facing led lights are steady red. I have a DJI Phantom 3 Professional drone. The user manual says that steady red represents a critical error. Can’t find out what that is or how to fix it. Any help would be appreciated. Thanks
This is normal when the AC is ready to fly. It simply shows you the front of the AC…
From the manual: “The Front LEDs show the orientation of the aircraft. The Front LEDs glow solid red when the aircraft is turned on to indicate the front (or nose) of the aircraft.”
It is the rear lights that give you warnings, should be solid GRTEEN when all is good ![]()
