Boa noite.
Sou iniciante e tenho uma dúvida em relação ao meu drone.
Não tenho a qualidade pretendida quando gravo com ele, gravo em 2.7k 24fps porém a qualidade de imagem vem bastante baixa.
Alguém pode-me dizer se isso é algum problema ou é normal e é facilmente resolvido?
Aguardo resposta.
Rodrigo_Rodrigues wrote in Portuguese…
Goodnight.
I’m a beginner and I have a question about my drone.
I don’t get the desired quality when I record with it, I record in 2.7k 24fps but the image quality is quite low.
Can anyone tell me if this is a problem or is it normal and easily resolved?
I await response.
The Reply…
You need to actually download the video from the drone, probably what you are seeing is only the video cache…
Você realmente precisa baixar o vídeo do drone, provavelmente o que você está vendo é apenas o cache de vídeo…
Thank you for your answer, but I saved the video in my gallery and the poor quality
image data continues
I think that shouldn’t be the problem
When I wrote you need to download the video, I am talking about downloading it from the drone to the controller or phone or tablet after the flight is over. This is entirely a manual process.
When you are filming a video, the drone sends a low quality video to the controller, phone or tablet and that is the video cache. If this is what you downloaded then nothing will change…
This YouTube Video might help explain what I am writing about…
I hope this helps.
I did it, thank you very much for your help friend.
Have an excellent day.
