Hi ! I just bought a Phantom 3 standard for a very cheap price. The battery was missing. The seller told me that the drone is working. My question is : before investing for buying a new battery that are quite expensive can i just power the drone with a 15.2V power supply to see if it works and then buy a battery ?
There is 2 flat plates for the 15.2V i guess and 4 little spring mount pins. Do i only have to power the main connector or do i have something to bypass or do anything else with those 4 pins ?
The rc controller seem to work fine with a steady green light after charging it.
Thank you !
