Phatom 4 will not return home
My Phatom 4 will not return home. I have tried it with someone elses tablet and it still would not return home and yet his does return home on that same tablet that I tried
From this i deduct that is a software glitch in the drone not the tablet.
Both my tablet and his have up to date software
I have a few questions to better understand your situation:
  • How did you attempt to initiate the Return to Home function?
  • What happened when you tried?
  • Has the Return to Home function ever worked as expected?
  • If it worked previously, what has changed since then?
Additionally, it would be helpful if you could upload the TXT flight log for that specific flight. You can use this link to upload your TXT flight log and then share the URL to the uploaded log here. If you’re unsure how to locate your TXT flight logs, detailed instructions can be found near the bottom of that page.
