Hi everyone, Im new here.
Ive had my 4 pro for over 12 months now and its been flying fine… All of a sudden out of the blue to started when flying in a straight line it veers off to the to the side sharply and if you yaw it to change direction it will keep veering off until you stop then start again.
It doesn’t matter the wind direction as sometimes its into the wind or if no wind at all still veers way offline.
Lately it been coming up with compass error, flicks between p mode and atti mode at times in flight and on the last flight of got everything. compass error, yaw error, speed errors.
I have recalibrated everything over and over. I have refreshed the firmware, cold calibrated the IMU, calibrated the compass out in the middle of a paddock and still all this happened, even at different locations. seems to be more and more every time I fly and Im loosing confidence in flying it.
Im always very cautious of where Im powering up that there isn’t any power lines, underground cables, concrete etc. I use a wooded board to take off from and it doesn’t seem to matter if its on a grass are or gravel area, dirt it still does it.
Ive uploaded 2 flights both are in totally different areas. The last flight
https://www.phantomhelp.com/LogViewer/NFR1J8ZNIRLRIYKE3N86
This flight things started to go haywire after already using 2 batteries. Taking off from the same spot.
https://www.phantomhelp.com/LogViewer/83CP5WKB4E5F4M42PBST
Im out of options and was hoping maybe somebody can help here on what to do next or what the issue might be. I feel its a hardware issue but Im no expert…
Thanks…
