Phantom 3 pro Problem
I have a problem with my phantom 3 pro, fist stop connecting to the DJI GO app, then control stop having control over the drone, when i try to upgrade the firmware it always fails, I have almost try every firmware update I find. please I need help
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.08.0080.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
Packet: P3X_FW_V01.11.0020.bin
Result: Failed.
========== 2022.06.27 15:33:14 =====================
Packet: P3X_FW_V01.01.1003.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
========== 2022.06.27 15:36:41 =====================
Packet: P3X_FW_V01.04.0005.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Packet: P3X_FW_V01.06.0040.bin
Result: Failed.
Packet: P3X_FW_V01.05.0011.bin
Result: Failed.
Packet: P3X_FW_V01.05.0030.bin
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.07.0060.bin
Result: Failed.
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.01.0009.bin
Result: Abort.
hello my friend, I have the same problem and I don’t know where to go, by any chance, did you find any solution???
Yes, my problem was a defective video card in the remote controller. I sent it to DJI and they replaced the video card. It was repaired and returned quickly…
I hope this helps…
