Hello. I have question about Phantom 3 standard Home position. When I used a return home option, the drone never land to the original take off location. I even mark the GPS location before the drone took off. Please let me know how to fix this?
How “inaccurate” is the GPS in a Phantom 3? It is generally accepted that the GPS will be accurate within 1-meter…
As I understand it, the Phantom 3 only uses the US’s GPS System and that DJI configured it to disable GLONASS (Russian GPS) at start up. I believe you can turn it back on, but you might have to do each and every time…
Thanks I will give it a try
