Hello
I have Problem with OLD but Good Phantom 3 4K i face with problem when i fly my Gimbal motor go uncontroloed LEFT and RIGHT so i need advice what to do is there any FIX ?, or need buy NEW set for my Drone …?
BR
Mario Jankovic
Uncontrolled left and right movement of the gimbal on a DJI Phantom 3 4K is often caused by a hardware problem, but you should first try software fixes. A bad gimbal motor, a damaged ribbon cable, or an obstruction could be the root cause.
Method 1: Perform software troubleshooting
(This is the simplest course of action and may resolve the issue.)
1, Check for obstructions. With the drone powered off, gently move the gimbal and camera by hand to check for any foreign objects or debris that could be jamming the motor. If anything is found, clear it and restart the drone.
2, Calibrate the IMU and gimbal. A full calibration can reset the sensors that control gimbal movement.
- Place the drone on a flat, level surface.
- Connect to the DJI GO app and select Camera View.
- Navigate to the settings menu and find the IMU Calibration option. Follow the on-screen instructions, making sure not to move the drone during the process.
- After the IMU calibration is complete, perform a Gimbal Auto Calibration from the Gimbal Settings menu.
3. Update the firmware. Outdated firmware can cause glitches. Download the latest firmware for the Phantom 3 4K from the official DJI website and update both the drone and the remote controller.
Method 2: Check for hardware faults
(If software fixes don’t work, the issue is likely a hardware failure.)
- Inspect the gimbal motor and ribbon cable. A crash or hard landing can damage the delicate flat ribbon cable connecting the gimbal to the main body, leading to erratic movement. A faulty gimbal motor can also be to blame.
- Check the vibration dampers. Look for split, broken, or detached rubber dampers that absorb motor vibrations. A missing or damaged damper can cause the gimbal to shake and spin uncontrollably.
- Check the motor alignment. After a crash, the motor shaft can slip out of position. Disassembling the gimbal is required to check if the axis shaft is properly aligned. For example, the flat side of the motor shaft must be correctly oriented when reassembling.
- Consider professional repair. If you are not comfortable performing a delicate hardware repair yourself, several drone repair shops specialize in DJI products. You can also submit an online repair request to DJI.
