P3P will not connect or even recognize the camera. Ive read every help topic on this and seems theres been a problem like this since the last update. Is there anyway to flash it back to previous data? Also i cannot calibrate the aircraft.
When flown LOS it responds well. But will not hold its position nor altitude.
I repair car audio amplifiers so i have some knowledge of electrical applications and the ability to conduct repairs.
Will someone please point me in the right direction?
According to Dji i have a compatible cell phone for video.
Thanks in advance…
Take that with a huge grain of salt, so to speak. Updates on the P3 series require more processor speed and RAM, depending on your device for that update. This is just my own opinion, however I have been flying a P3A for 4 years and have never done a firmware update on the aircraft. There are many posts on the latest firmware which is old at this point and have issues. ( Knock on wood ), I have never had an issue whatsoever even with app updates. There are options available, depending on the firmware version you have.
Is it possible to flash back to a previous firmware?
I do not think you can as best I recall if you are above 1.9 . I might be mistaken but think that’s correct.
Morning, you need to read and read some more lots of info on the forums about downgrading and how to do it using a Debug file. But first you need to make sure your camera work, also you need to make sure your camera flex cable and gimbal board is good. There is ways in the forum to test things like putting an older firmware on your Sd card putting it in the drone, starting the drone and RC. It will then produce a hidden log file which you can then post in the forum and ask senior guys to help you decypher it and tell whats wrong. Bless
Hello I have a phantom 3 pro and it says calibrate the compass. Well I’ve tried to in many different places it just keeps saying to strong of magnetic interference! I have posted on here a month or so ago an I can’t find that post again. I did do what was replied back to me at the time but nothing has worked yet ! Any ideas as what might be wrong or going on? I haven’t flown this drone in like 3 yrs. I did break the camera last time I flew it but I bought a new one an installed. The camera does work I can view, turn camera so I assume it’s working
