Hello from Northeast England
Welcome to the forum @Paul-Aikido_3! ![]()
Thank you
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, “Home point Updated.”
Fly On and Fly Safe…
Hi from southwest
C
Howdee to You
Hi , yes I have accomplished the A2 C of C certification to complete my hat trick of being able to fly in the relevant A1,A2 and A3 categories. At 77 yrs old I am rather proud that this old dog learned some new tricks.
Congratulations…![]()
