Hi, all. I’ve got a Air 3s as a Christmas present from my son’s and my daughter. Ive not even opened the box, as im looking at tutorials on YouTube. And thought this would be a good forum to join. As im sure there’s a wealth of information to digest on here..
This a new concept to me, could be quite challenging for me to be honest ! I used to have an interest in 1/8th scale car models, petrol (Gasoline) combustion off road models, and nitro cars as well.
Im from Loch lomond (Scotland) Im 56 year’s old and always had a passion for remote control models. Back many year’s ago I had a Tamiya sand scorcher off road VW Beatle.. But this Is my first aircraft. So lots of regulations and a massive learning curve to endure ! Ive read there’s a flight simulator built into the RC2 controller, That’ll be my first state of play for me, once I understand the rules and regulations.
Thanks for taking time to read my first initial post.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
You might want to also check out the Mavic Pilots Web site as they have are primarily a DJI specific site…
Your kids paid a lot of money for that Drone, put your phone number on it. If your drone gets lost or stuck in a tree and it finally comes down when you are not around, give the finders an opportunity to contact you so it can be returned.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, “Home point Updated.”
