I’m an experienced DJI Drone pilot (Phantom Pro) with a brand new MINI 2.
Everything looks good on the app but, when I start the drone using the joystick, it sits & hums along quite nicely - for about 10 seconds then it tries to take off no input from me!!
I’m indoors. Thanks goodness, the first time this happened I was holding it firmly!
I have to RTH or stop it with the Joystick to get is to shut down.
What am I missing??
I am sorry to hear that. I also have a mini 2 and I am very fond of her, (she even has a name…).
I have flown a friend’s Phantom and know that it responds and reacts differently, so perhaps, and I’m being presumptuous, but let’s go back to ghe basics and don’t expect you M2 to act like your Phantom.
I’ve never left my M2 to just idle. After the preflight checks (info to follow…), I start the motors, let them idle for a few seconds (nowhere 10-seconds…) and then lift off…
You know, the M2 can launch using the Take Off Button (it will idle for a bit and then take off…) and maybe the M2 will also take off if you leave it idling too long…
Any case, as I wrote, “More Info to Follow…”, here is the gist of what I write to newbie pilots and perhaps you may need to change up your tried and proved routine that you developed for the Phantom.
-=-=-=-=-=-=-=-=- Link to User Manual at end of Note… =-=-=-=-=-=-=-=-=-=-
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
When the motors start the flight has actually started. Without stick input the M2 will “hover”. If the Flight Controller thinks the M2 has descended the FC will command more thrust. In your incident I suspect the FC mistakenly thinks the M2 is descending. There are, at least, a couple of reasons this could happen;1) the barometric pressure is rising causing a decrease in indicated altitude, and 2) the IMU wasn’t calibrated starting in a cold state and is still in the warmup phase.
If you want to pursue this you will need to provide the .DAT log file found on the mobile device. Look here
https://mavicpilots.com/threads/mavic-flight-log-retrieval-and-analysis-guide.78627/
Section 3,
sub section Mobile device DAT files (DJI GO 4 & DJI Fly)
And, you will need to turn off automatic synching with DJI. If synching is on then the .DAT will be deleted once it has been uploaded to DJI.
EDIT: It’s also possible the controller has a small bias and is actually sending an altitude increase when the sticks are neutral.
