New guy
Hello from Scotland, new to drones got a mini 4 for my Birthday
Look forward to reading all about drones.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
You might want to also consider joining the MavicPilots Web Site, it is almost entirely dedicated to DJI Drones…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, “Home point Updated.”
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum!
