Hi.
I have had the Neo since September as a new recruit to the world. I tend to read and research everything and go slowly slowly seeing how things work. I was so impressed with the Neo I bought an Avata 2 but haven’t flown it much yet until I am fully happy with the Neo
However
In the space of a few days I had 2 Fly Aways while using the RC-N3 controller.
The first only had 8 or 9 Satellites . Home Point was updated. It gave a No Satellite Positioning message then started flying backwards then off to the side before crashing into me
The second one was much worse
18 to 20 satellites, Home Point updated and hovering 90 ft above my head (above Home) until it went bonkers.
at 180 degrees through a 360 yaw I got a No Satellite Positioning message (dropped to 8 satellites then back to 11 then 15 in 0.5 of a second)
When it completed the 360 and I centred the yaw the motors went mad then it shot off in the direction it was pointing when the Satellite loss message came up.
It reached 52.6 mph before it hit something solid . Outright dangerous
Despite it heading away from Home (as it was always above Home) it went into Go Home mode as it was flying away from Home ! . Hitting Cancel didn’t stop it
I see there is a lot more data in the Offline Log Reader .
It clearly was fully out of control as Normal mode restricts it to 6 m/s (about 13.4 mph)
There seem to be lots of Fly Aways on the Neo with the Controller
I have sent all the data to DJI
Is there anything else I can do or pull from the logs that proves they have a serious safety issue with the Neo flown from a controller ?
Thanks in advance for any help and advice
