I need some example Mavic Mini .DATs that are created by the DJI FLY App. They will be used in the reverse engineering effort required to include the MM in CsvView/DatCon. Here are the instructions to retrieve a tablet .DAT from the Go 4 App - apparently they can be used to retrieve .DATs from the Fly App as well.
Retrieving a V3.DAT from the tablet
If possible, the corresponding .txt would also help.
It would also help if someone could create a .DAT by 1) starting the Fly App and waiting until it’s finished it’s startup and then 2) powering up the MM and let it sit for 2 minutes without doing a motor start.
A more involved test .DAT is needed where
0) remove the props from the MM
- start the Fly App
- power up the MM
- start the motors
- grab the right front motor to slow it down for a second or so, then the left front, then the left back and finally the right back.
