When the drone powers on there is no noise bit when i try to vonnect the control to the app the controller starts loudly beeping. I have tried to calibrate, which i have heard to be a solution to this issue, it however the app wont register the movements of the joystick. What can i do?
When did the remote controller last work properly? Have you changed anything (installed firmware, etc.) between now and then?
What color is this status light when the remote controller is beeping?
I have also been having the same problem with my Phantom 3 controller and Phantom 4 controller.
Usually beeps forever 90% of the times i use them. The light is usually red but sometimes it’s green.
I really want to just remove the speaker if possible.
The controllers work fine besides that annoying beeping that almost always happens. About 10% of the time, it doesn’t beep though, just luck.
How do people fix this???
Most times, the remote controller beeps when the remote controller sticks need to be calibrated. Try that if you haven’t done so already.
Also, make sure the remote controller sticks are centered when the remote controller is powered on. When not centered, that’ll make the remote controller falsely detect a bad calibration.
