Mini pro 4 controls freeze after take of a moving botr
Dear Dji help… I took of a moving boat withe my mini pro 4 as soon it was up about 8 Mt the controls @RC N 2 freeze I could not turn the drone but I could go up butt refuse to turn or go forward… Luckily the boat turn around after a 100 Mt and I could manage to bring it down to the boat as we were moving to the drone… My question is what make the controler to freeze is it because the controler was moving?? Is there any settings I have to do before taking of a moving opject
ARE THER NO REPLY ON THIS >?>
We might be able to help you if you can provide the .txt log file for the flight. Take a look at
to see how to retrieve the .txt log file
Every instruction ever written for DJI tells you not to take off from a moving vehicle (and in the US is forbidden by FAA rules).
But ignoring that, it may be that there are radio, radar or other RF sources on the boat that are interfering.
Did you check before takeoff that you had sufficient satellites to make the icon go white, and did you get a message that your HomePoint was updated? If you miss these, you may get all sorts of problems. It is definitely not a good idea to take off from a moving boat.
