When viewing a shot 360 panorama, the east and west side see a noticible drop. It’s as if the ‘southern half’ of the image is set lower and that there’s a slope.
If I recall correctly, the pictures taken did follow the horizon every single time, which makes it strange that viewing the stitched result sees a clear difference in the ‘height’.
I tried taking the panorama with the gimble all the way down as perhaps that would’ve fixed it, but to no prevail. Anyone knows why this happens and how to fix it?
To reset the levelness of your camera image, you will need to reset the calibration of the Gimbal, either automatically or manually…
First you need to set your drone on a flat surface and you should have a level surface at approximately the same level as the drone… My drone sitting on a thick dictionary on the kitchen table looking across the room at the kitchen counter works perfectly for me…
Go to the Control Menu from the three dots on the top right of your Fly App, Tap Gimbal Calibration, and in the new window you will have the option to set it automatically or manually. I use the manual and click the tilt left or tilt right as need so that the kitchen counter is perfectly in line with the center line on the screen… And that should do it.
By the way, the image you provided is a 180-degree panorama, not a 360-degree Globe or a photosphere…
