is anyone one using a wide angle lens on their Mini 3 Pro, if so is it any good
I’d give serious consideration to an anamorphic lens instead. Unless you need to get absolutely as much as possible into the frame, anamorphic lenses increase the width of the letterbox frame with significantly less barreling distortion, and lends itself better to ‘that movie look’. The only catch is that post-production squeeze must be adjusted to properly scale objects for height. Check out some youtube videos about this if you have any questions.
