How would I know if I need to re calibrate my IMU setting ?
You should calibrate the IMU when:
DJI GO indicates the IMU needs to be calibrated
The sensors in the “Sensors” section of DJI GO are not in the green range
The aircraft is not able to hold its horizontal or vertical position when hovering in place outside while the wind is calm
The aircraft has taken a hard impact (after crashing or accidentally dropping it)
It takes a long time for the IMU to finishing initializing on startup (due to last calibrating the IMU while the aircraft was warm/hot)
