Looks like another Mini wind and propulsion issue to me. Winds at ~200ft are stronger and in this instance blowing away from you. It would have never made RTH nor in Sport IMO.
409.6,TAKEOFF PERMITTED0
409.6,IN FLIGHT0
411.9,1HOMEPOINT UPDATED. RTH ALTITUDE ADJUSTED TO 500 M! X
435.2,RETURNING TO HOME0
436.3,RETURNING TO HOME0
440.3,IN FLIGHT0
445.7,RETURNING TO HOME0
446.7,RETURNING TO HOME0
447.9,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
447.9,STRONG WIND WARNING
447.9,JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!NV"
458.3,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
458.3,JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!
460.6,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND
472.7,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
481.6,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
484.6,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
495.3,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
495.8,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
501.3,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
502.4,REMOTE CONTROLLER SIGNAL LOST!
504.2,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
504.2,STRONG WIND WARNING
512.2,:REMOTE CONTROLLER
512.2,REMOTE CONTROLLER SIGNAL LOST!
513.9,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
513.9,STRONG WIND WARNING
516.9,REMOTE CONTROLLER SIGNAL LOST!
517.6,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
517.6,STRONG WIND WARNING
520.7,:REMOTE CONTROLLER
520.7,REMOTE CONTROLLER SIGNAL LOST!{
526.0,GNO GPS SIGNAL. AIRCRAFT UNABLE TO HOVER. FLY WITH CAUTION (CODE: 30008)
526.0,TAKE OFF WITH CAUTION (NO GPS)
526.0,XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
526.0,STRONG WIND WARNING
526.0,JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!`
526.0,:REMOTE CONTROLLER DISCONNECTED FROM AIRCRAFT (CODE: 30029)
526.0,RC SIGNAL LOST
534.7,:REMOTE CONTROLLER DISCONNECTED FROM AIRCRAFT (CODE: 30029)
534.7,RC SIGNAL LOST
534.7,REMOTE CONTROLLER SIGNAL LOST!3
541.2,:REMOTE CONTROLLER DISCONNECTED FROM AIRCRAFT (CODE: 30029)
