On the 3rd December 2019 I took my Mini for a flight. Satellites acquired initially were 11 and home point was set. I took the drone up to 90ft the came down to 84ft. I started to move forward slowly and at about 15ft the drone suddenly started behaving like it was not under my control. I tried to bring it back manually but it just kept flying away from me. I then put it into RTH but no response it just flew away. We did go to the location indicated on the map where it got lost but never managed to find it. Flight log included.
This appears to be yet another case of strong winds. The mini could not handle the winds. The higher you went, the stronger the winds became.
44.5 (MAX POWER LOAD REACHED. FLY WITH CAUTION
46.6 46.6 IN FLIGHT0
62.8 AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
62.8 (MAX POWER LOAD REACHED. FLY WITH CAUTION
76.2 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
76.2 STRONG WIND WARNING
76.2 /STRONG WIND. FLY WITH CAUTION AND LAND PROMPTLY!
77.1 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)
81.2 82.2 82.2 RETURNING TO HOME0
83.2 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)
83.2 STRONG WIND WARNING
83.2 /STRONG WIND. FLY WITH CAUTION AND LAND PROMPTLY!
88.2 89.5 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
110.1 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)
112.2 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
125.9 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)*WEAK SIGNAL. ADJUST ANTENNAS (CODE: 80016)AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
126.6 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)*WEAK SIGNAL. ADJUST ANTENNAS (CODE: 80016)
128.1 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)*WEAK SIGNAL. ADJUST ANTENNAS (CODE: 80016)AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
128.9 +STRONG WIND. FLY WITH CAUTION (CODE: 30149)AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
130.2 130.7 FAILSAFE MODE IN PROGRESS
