Every time I turn on my Mavic Mini remote control an annoying beep starts and does’nt end till I firts turn on the drone, the drone communicates with the control, then have to turn off the drone (as requested), go to control opperations and callibrate the control. The first months I had the drone this did not happen. Please help!
You may have a bad controller. It does happen. In the calibration process, are you also calibrating the dial wheel on the left side?
I are right. Problem solved. Thank you very much!
